Hi All.Seen a post from DJMASTER G on 26thJan 2012 got the same problem.Iam wondering if anyone knows if he solved the problem of the buzzing noise coming from the bedroom window when it's windy and when opening and closing the bedroom door.Many Thanks
It's loose and vibrating silicone sealant between the window and surrounding plastic trims, peel it away and then try it with opening the door and the noise will have gone, then just reseal it
