Non(?)-notifiable work in a bathroom
23 Jun 2011
Berkshire
I am reworking a bathroom. I propose to do the following:
1. Remove the existing wall unit which includes a shaving socket and some 12V halogens (via a transformer)
2. Disconnect the existing ceiling fan
3. Remove the existing main light
4. Install ULV LEDlights in the ceiling (IP55 rated)
5. Add an occupancy sensor for the above, also in the ceiling
6. Re-connect the fan, now fitted with a humidity sensor (possibly located elsewhere in the ceiling as it is currently just about above where the new shower will be)
7. Install a heated mirror incorporating LED lighting
The current switch is outside the room; it will become redundant although I might replace it with a double pole to isolate the lights/fan (or possibly just the fan).
Everything in the ceiling is outside the special zones, and the mirror will be more than 60cm from the shower cubicle (I think, I'll have to check), so also outside.
I don't think any of this is notifiable - which is just as well as I've done 1&2! Am I right?
The current switch is outside the room; it will become redundant although I might replace it with a double pole to isolate the lights/fan (or possibly just the fan). Everything in the ceiling is outside the special zones, and the mirror will be more than 60cm from the shower cubicle (I think, I'll have to check), so also outside. I don't think any of this is notifiable - which is just as well as I've done 1&2! Am I right?
Provided you are satisfied that none of the work is within any of the prescribed 'zones' then, yes, you are right in saying that it would not be notifiable (in England).
Kind Regards, John
