have you give it a touch more secondary air
Pardon?
call a professional its obvious you dont know about oil burners
That's why I'm here!?
Pardon?
Pardon?
The baffles ideally should be pretty clean with a few hard sulphur deposits on them
John![]()
As the burner is only grumpy at the first start of the day and is ok thereafter there really can't be too much wrong with it.....
It would be good to know the actual pump pressure and CO2 readings though - as the unit was fitted with a nozzle for 35 sec instead of 28 sec oil there will be a significant difference in the pump pressure.
Personally I think the pressure could be a little low, but its not something to guess at. You'd do your customer a great favour by cleaning out the boiler gas passages, and wire brushing the baffles though!
The baffles ideally should be pretty clean with a few hard sulphur deposits on them - if you find copious amounts of soot - especially oily stuff - then the burner is miles out. Make sure you clean the ledge just before the flue!
Enjoy![]()
John![]()
