Why would it be cheaper to run? All electric heaters are 100% efficient.Have you considered sitting on a heated blanket? Much cheaper to run.
So that heated blanket would warm the room up then or just the part of you that needed warming?Why would it be cheaper to run? All electric heaters are 100% efficient.
All parts of me need warming and not just the bottom. I have a column of hot air rising around me.So that heated blanket would warm the room up then or just the part of you that needed warming?
I warm up through radiator and jump into bed. It's the same thing, and I don't need special preparation because I am usually at the computer + radiator before bed. The radiator warms me and my chair. It also warms my ears. If that isn't direct heating, I don't know what is.An electric blanket, is a very much more efficient method of getting into a warm bed, compared to warming the entire bedroom.
100w gives you less heat than the 500w I have. You pay less for being colder.
It depends on what, the lesser heat, has to warm up.
Because it uses less power [say 50W instead of 2kW]. The end goal is to improve comfort rather than raise the temperature of the building. As such, sitting on it when it's on means I run the central heating a lot less.Why would it be cheaper to run? All electric heaters are 100% efficient.
I'm not convinced a blanket, is the best method, an electrically heat pad might be safer.
It's called a blanket but it's designed to go under a sheet. I am not sure what the proper name for that is.
Silentnight Winter Warmer Electric Blanket
Made from super snuggly fleece material Fast heat up and 3 heat settings Designed with overheat protection Easy fit straps provide an easy secure fitwww.silentnight.co.uk
