Old damp proof holes in bricks
13 Oct 2010
Cheshire
I have noticed many holes on the lower external bricks to our house as the old damp proofing plastic caps have gone. This as treated previous to us moving in so I have no idea what happened. Suffice to say the lower internal wall around the fire hearth is crumbling through the wall paper.
Shall I fill the holes in with mortar to stop damp getting in ?
Filling the holes in will not achieve anything if it's that bad on the inside. You probably still have rising damp, and it looks as though the previous attempt at curing it has been ineffective.
I remeber a prog on TV some time ago proving there is no such thing as rising damp. Impossible for water to travel up bricks. It's probably coming from outside.
Get a soft brick and stand it in a bowl of water for a few hours and see the water rise up the brick.
"Rising damp is widely misdiagnosed in existing buildings, based on the incorrect interpretation of visual evidence and the readings of moisture meters. Because of a highly successful sales campaign for over 30 years by specialist remedial contractors installing injected 'chemical dampproof courses', this misdiagnosis of rising damp has also become synonymous with a diagnosis of a lack of an 'injected chemical damp-proof course'. Although this has been very good for business, it has often resulted in a waste of the clients' money and resources; original plasters and finishes have been destroyed in the process of installation, and unnecessary damage has been caused to original structures by the drilling of irrigation holes. In addition, money that might have been spent on more cost-effective maintenance or repair works has been wasted.
Whilst injected chemical damp-proof courses may provide some protection for certain types of structure if properly specified, their general application is rarely the most cost-effective way of controlling damp problems in buildings, and may be wrongly specified and ineffective. In particular the more generally available water based products may only form an effective ‘hydrophobic band’ if applied to a dry wall after it has dried out. This can prevent their effective installation in damp walls." ...Took this from the building conservation site.
It's widely proven that this type of, so called, damp proofing is seldom 100% effective, indeed if it achieves n% it's regarded by the companies touting them to be a success (read the small print) only a fool and his money, oh! and the misled, would buy this nonsense. Your own case is a perfect example, ye gads, injection course, crumbling bricks, covers popping off, what next? http://www.heritage-house.org/pages/managing-damp-in-old-buildings.html
I think filling the holes with a coloured to match pointing mix, lime (if the walls are stone) cement if brick, will enhance your buildings look, it most certainly won't damage it, then let's try and figure out what's really causing the problem!
Start with the fact that the effected walls are around a fire hearth, could it be that the hearth has had no insulating against the structural wall, heating natural stone, or bricks not made to be refractory, over time could make them crumble, hmm! not likely. On the other hand acidic seepage mixed with damp, through to the wall might be the problem.
All of this is conjecture of course, what we need to do is establish the facts, like what age is the building? what is it's build i.e. What kind of fire is in the hearth now? and what preceded this?? Is there any other abnormality i.e. drains, sewers, lack of drainage and the like that you can ascertain??? ...pinenot :confused: [/i]
Te tv prog did stand a brick in water for a long time and it didnt absorb any water. fact !
Well the house was built in 1883. The outside wall adjacent to our side entrance has concrete flags meting the brickwork as well as being slightly higher though I would think this isn't a problem as the path is sloping away from the house carrying water with it. When we moved in the previous owners had some damp course and we had a guarantee that lasted a few years. Sadly, it took me longer than the period to realise. The lower bricks on the outside wall go green with moss over winter. I have to keep clearing it off. We have a coal fire as did the previous people.
What kind of brick or stone is the wall built of?...pinenot
[quote="tony1851"Are damp-proof courses in buildings unnecessary then?
This is beyond words.[/quote]
Unless the bricks are below the water head (pressure of water v gravity) damp cannot rise unless the material it's rising in is equipped with one way valves and an impervious skin, like a tree, In fact moisture/damp can only rise to a height that the pressure behind it allows, it may wick up slightly above this, but not to any great degree. The bricks or blocks close to the ground are colder than the those above, and this variation can cause condensation.
"Hmm! therein lies a big pointer...the more we warm the building above the more rising damp becomes an issue, some companies have made their millions peddling this dogma! "
A search with Google returns only British links to damp proof courses, non other, is the rest of the world exempt from damp??...interesting subject
Pinenot;
When you studied bullding construction at your college/university, did you pay tuition fees?
If so, sue them.
