Old Hot Water Cylinders?
  • Thread starter Thread starter Brigade77
  • Start date Start date
B
Brigade77
Snatched an old copper hot water cylinder of my Son's refurb job & now that I'm retired, locked down, bored & totally useless I thought I'd have a crack at making one of those whirlygig wind spinners that I've always been reluctant to pay for.
Cut the cylinder up easy enuff & it seems to be made of mostly 0.9mm sheet, which is ideal for what I want.
So how do you polish this copper?
I've tried everything & yet nothing seems to bring it to a shine. Is it a copper alloy???
I guess it depends on what polishing medium you have used so far?
One of the best polishing compounds is Solvol Autosol, but if the copper is scratched then you may have to go through the fine grades of wet and dry paper.
Jewellers rouge is another, but best used with a mechanical polisher.
John :)
Yep, done that. Nothing seems able to bring it to a shiny copper ?
Curious - even if there was an alloy involved, polishing shouldn't affect things to any degree..
Have you tried wet and dry paper down to the metal? Just wondering if the cylinder was foam coated which has left a deposit.
John :)
You need to sand it back first using fine graded so it's shiny then polish
If it is really bad I'd start with wire wool rather than sandpaper which will scratch the soft metal. For tarnish you can use Solvol or similar, but on a nylon scouring pad rather than a cotton rag.
sometimes they are sprayed with a paint that's roughly copper coloured, so you'd have to get that off first.
I have a modified bench grinder with 2x 6" polishing wheels & 5 types of soap, 3 different grades of wire wool & wet n dry paper from 120 to 3000. Still I cannot get this to shine.
*Please don't use steel wire wool to polish soft copper, little bits of steel get embedded in the copper & eventually rust . . . .
