One radiator always off?
28 Aug 2017
Hi
My soster has been told by a plumber that the radiator in the hall must always be off because it 'regulates' the worcetser combi boiler.
Does this sound right?
Ive just replaced it after decorating and put it on and we have lost water pressure so boiler is now not working.
JohnD
Party? What party?
15 Nov 2005
South
Cook Islands
More likely it should always be "on" because it is close to the room thermostat.
You need to top up the pressure and bleed the rad(s)
CBW
26 Sep 2019
North
I’ve never known a radiator to be off so it regulates any boiler. As per John, top up, bleed the hallway rad and any others on the first floor.
28 Aug 2017
Thanks ...now the key has got stuck in the boiler.
It wont repressurise without leaking or come out!
Time for a cuppa and a calm down.
Any ideas of how to get it out?
9 Sep 2005
Sussex
Spray WD40 up into the key and hopefully the O rings will "unstick".
You should always apply a little mild soap (preferably silicon grease) to the O rings before sticking the key in....they will snap with excessive force.
Once you've re-presurised to 1BAR MAXIMUM (constantly tap the gauge as they suffer from stiction) put the heating on (with the boiler temp turned up) and carefully monitor
the pressure...if it goes above 2 bar there's a problem..do not let it go above 2.5 bar otherwise the safety valve can open and it's a PITA on many Worcesters to fix.
You'll also need to balance the radiator and ensure it doesn't heat too fast (I'm assuming the room thermostat is located in the hallway) otherwise the heating will turn off too early before the home has warmed.
It's rarely a good idea to take radiators off for decorating....but it's a good earner sorting out the aftermath. :)
28 Aug 2017
Tha ms gasgurj I think I have sorted it ( so car pressure is stable a d rads are hot). That "lite job" has taken my day out.
