Hi, i have installed an outdoor camera. The top of the block is attached steady but its not completely closed on top. What do you think? Should i apply some silicon on top? Or should i remove it and re do it?
Defo stick a bead of good quality silicone across that top gap, but just make sure you leave the very bottom clear so any trapped moisture or condensation has a way to drain out. Taking the whole thing down to redo it is overkill if it's already mounted solid, so a quick seal on top will protect it from the rain and save you the hassle.
