Two part question. I'm getting a new kitchen fitted. The original was stuffed into an extension on the back of the original kitchen about 15 years ago. This has actually made rewiring for the new kitchen remarkably easy. Things like the cooker feed and some sockets already had the channels and cables in situ. Where I want to put the new appliances. Admittedly they were all trimmed flush so I've ripped out replaced and rough plastered.
It's like for like replacement so I'm guessing I shouldn't fall foul of any part p regs?
The second question is about a fused spur.
I've got one right where I want the switch. I've dropped the fronts of the spur and the adjacent socket. There's ring main through the socket and a short length going to the fused spur. So far so good. I want this switch for an extractor. The problem is the spur currently runs an outside light. And the cable rather than being chased into the wall disappears off into the cavity then reappears outside. Ideally I don't want to chisel anymore channels into the the wall. Is there a problem with taking the the light off. And just running the cable to the point outside the house corresponding to the extractor position and poking a hole from outside to in again. It appears to be regular grey sleeve twin and earth so I would be inclined to sheathe it in something a bit more weather resistant. I would have approximately 60cm/2 foot of cable on the outside wall.
Sorry it's so long winded for a first post
BTW I'm Alan. Keen diy,er. Professional life saver
