Outside Lighting Feed
3 Oct 2016
Hi
I am wanting to put a couple of LED Floodlights along the front of my house and a couple more in a barn that is next to the gable end of my house (3 meters away) , the only feed I have outside is a small floodlight on the gable end , (next to the barn) this is run off the house lower light circuit .
It would be most probably be ok ( I think ) if it was only going to supply 4x 30W LED Floodlights , but someone could change that to a higher wattage later ! .
The problem I have is that the CU is in the middle of the house , so very difficult to take another feed from it .
So what I was thinking was taking a feed from the lower ring main ( a lower floor socket next to the gable end , and somehow fitting it into a 5A fused spur , using 1.5mm2 cable , then take my feed from that to the 2 light circuits outside ! .
Spike44
Also use a double pole switch so that the outside lights can be fully isolated ( Live and Neutral both disconnected ). This will prevent damaged and/or water logged outside lights from tripping MCB or RCD protecting the lower ring main.
Yes, of course it will be ok. 6A @ 240V = 1,440W
So what?
Someone could do anything.
No need but you can if you want.
Anyway, how will that be different? It's still 5A.
You should be fine to come off the existing supply. Your proposed load is about the same as a single old fashioned light bulb.
If we worried about someone modifying a circuit incorrectly in the future then we’d have to wire everything up in 120mm² cable just in case someone buys an X-ray machine and tries to connect it to an existing circuit.
Aargh. I was about to make a disparaging comment about one of the ‘regular’ contributors about this issue. But the nice TTC held me back…
