Outside tap, supply from existing Washing Machine supply
use this makes the install look better and all your connections will be inside.
the water regs require a double check valve fitted inside to stop possible contamination through back flow, you should also fit the pipe to external with a very slight angle to outside and an isolating valve, in winter close valve and open tap to empty pipe other wise you may get a burst pipe
no regs state they want them fitted inside now.
then they don't freeze in the winter.
I assume then there is no requirement for the tap to have NRV ? Otherwise it will be 3 :shock:
