oven / cooker wiring
2 Nov 2011
Dundee
Currently have a single cable going back to an MCB. Re-fitting the kitchen and require the cable to be an additional 3 metres away from original outlet.
Is it acceptable to join the cable in a junction box to add the additional length of cable? The reason for asking, is that it is extremely difficult to get another cable up to the consumer unit, as I have a solid concrete and tiled floor in this area.
It's acceptable providing the junction box is easily accessible for inspection, test and repair.
If this can not be achieved there are other methods that can be used, a popular one being by the use of maintenance free junction boxes. Which BAS will be happy to hear they now are recognised as a BS. (BS EN 60670-22.) or may be not!
Does the cooker circuit have an isolator?
Isolator not visible,but may be behind the housing. Single circuit definately goes back to an mcb in the consumer unit. I never fitted the kitchen, it was proffesionally fitted 12 years ago. Will find out when I dismantle the oven housing. Does this matter now, seeing I am about to change the wiring ?
Can probably fit a junction box in an easily accessable place upstairs and exted the cable. that will take care of a cable to the hob. will just have to figure out the easiest way to get a cable to the combi oven, which will also require a single cable back to the board.
Thanks for your help
If you intend to use a junction box then make sure that it can handle the size of cable you are using. For the one quoted above the max is 4mm.
Most 32Amp Cooker circuits tend to have 6mm cable - though the size of the cable and the MCB protecting it should be determined by the load expected from the cooker/hob which should be outlined in the manufacturers instructions.
Also be careful you don't stray into Part P terriority.
