Oven & hob connection
21 May 2009
Northumberland
Hi all, any help appreciated.
Ill first explain what a need to do.
I have an electric oven & gas hob to install.
Cooker socket is to the left of my new oven,now obviously my new oven will connect directly to the feed on the wall from the cooker socket which is situated behind the cooker.
My problem is that i have nowhere to plug in my cooker hood & ignition for my gas hob.
The socket to the left is already spurring a socket across the other side of the room so i cant use this.
I was originally going to spur off the cooker supply but this has been frowned apon by many so i think that one is out.
My question is can i in any way use the supply from the cooker supply,i understand that this is a radial circuit protected by a 40 amp fuse.
Anyone help my plight??
What rating is your oven? in KW or watts?
If its a single oven and below 3kw, you may also plug this in, in which case fit the dual backbox with two sockets.
