I suppose the other thing to consider and this seems like a major one to me. If you pour your own Padstone it will take a few weeks to reach full compressive strength. If you buy off the shelf then this will be ready to use as it is.
My architect replied and simply said "3:1 mix would be OK"!
Think I will use that premixed bagged stuff. Which does seem to have smaller stones in it... I would have thought latlrger stones are stronger.
No he hasn't but I'm happy with itBack to my comments from an earlier post - has the architect provided calcs, specs, etc beyond what is on your plans?
I'd want all this stuff in writing from him...
3:1 using ballast/all in3:1. WTF? That's a mortar mix! Top architect bloke you have there.![]()
I'm happy. Spoken to the architect, a builder and done my own research. I consider a cast Padstone in this situation to be better than the other options.Will BC be happy with his verbal assurance?!
LOL. So you know the ballast ratio that the mini digger scooped up at the merchants?3:1 using ballast/all in
The point is, not only are architects clueless about specifying padstones, but no-one specifies a concrete mix as "3:1". You've hit the jackpot there.
I hope your concoction copes with the bearing shear, which is down to a bit more than vibrating the shutter with a drill
BTW, you may need a C40 designed mix, and its not just about sand/cement/gravel, as water plays a massive part in the 28 day set strength
I do love your optimism but I would probably agree with you tbh. Still going to do what I've suggested tho!Option 2
We’re trying to help you here mate.I'm happy. Spoken to the architect, a builder and done my own research. I consider a cast Padstone in this situation to be better than the other options.
