Paint finish on walls & ceiling - same or different?
Discussion in 'Decorating and Painting' started by xyz321, 31 Dec 2016.
  1. xyz321
    xyz321
    29 Apr 2012
    281
    Thanks Received:
    London
    Country:
    Hi, a daft question but normally do people match the finish on Wall & ceiling? I am getting dulux diamond matt for hallway/landing walls but just wanted opinions on whether to get same finish for ceiling or go with soft sheen or something similar?
    Ta
    [​IMG]
  2. Pigeon85
    Pigeon85
    6 Feb 2013
    702
    Thanks Received:
    110
    Oxfordshire
    Country:
    I always advise a matt finish for both walls and ceiling, more so for a ceiling because of light reflection on a silk finish just looks terrible in my opinion.
    Same goes for walls unless you have very smooth wall it will show up every blemish.
  3. Sponsored Links
  4. misterhelpful
    misterhelpful
    19 Feb 2011
    3,210
    Thanks Received:
    525
    Ohio (formerly Mid Glamorgan)
    Country:
    Spot on, although that doesn't mean you have to use Diamond Matt on the ceiling - a decent vinyl matt or even contract matt can be used.
    If you have textured ceilings, then silk is more forgiving, but silk on a flat ceiling is a bad choice, unless it is perfectly flat and you are a good enough painter to avoid roller marks. Soft sheen would be the highest sheen I would recommend on a ceiling, in any case.
  5. xyz321
    xyz321
    29 Apr 2012
    281
    Thanks Received:
    London
    Country:
    Thanks for your replies
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
