Painting Dry Verge ?
1 Nov 2006
Lancashire
Hello folks
Does anyone know if it is practical or worthwhile to paint dry verge units , please?
Ours are getting on for 20 years old , but still in good condition apart from having faded from the original black colour
If it's worth doing , and will last , I'll do it myself and hopefully save the cost of replacement
Painting masonry is fine for people who do not know what they are doing .
I've never seen a car bumper on a house.
The immediate effect is irrelevant - the long term consequences are significant.
Personally i have no problem with using masonry paint or plastic paint.
Example......my B&Q composite front door was coated with Bedec MSp (Multi Surface Paint) some years ago. The gloss is still great, no peel or discolouration, looks as good as new. No primer required, it's Oxford blue.
The pebble dashing on my 2nd gaff (called hard cast render here as they use whin stone) had been sprayed white, and naturally enough overspray was evident on the SVP and down comers. I treated this with B&Q black gloss and that too has remained stable.
Rain casts off the render perfectly well, and there isn't any damp anywhere.
Car plastics (ABS usually) are different - they need a special primer which is clear and colourless, and very thin.
John :)
and you'll never tell us what they are
So why do they make paint especially for uvpc.?
And masonry paint?
Hello folks
The second you paint or render any part of a building, you immediately introduce a maintenance issue. Success will depend on the prep. The better the prep the longer lasting the finish. I doubt anyone is going to spend a lot of time prepping a dry verge.
I wouldn't. I'm tempted to get my (metal) garage door re-sprayed, but that is on the ground and can be meticulously prepped.
