Palette wood cladding on block wall - concerned about weight
If the external wall is decent and flat I would advise direct fix with no battens. If appearance (of the fixings) is an issue, consider stainless cladding screws. These are authentic and most think add to the look.
If you must batten, add a vapour barrier to the battens before fixing the pallet wood. (the external wall - internal wall is fine)
The weight is less than adding another sheet of plasterboard , I planed , sanded and stained mine and finishing with danish oil .Just pinned to studs.
That's beautiful @foxhole! Exactly the sort of colour we want. Can you link me to the stain and finish you used, please?
Just used a variety of Colron wood dye, (not water based)then mixed a few to give range of colours.Then coat of danish oil .
