Panasonic bread maker SD 2511
Discussion in 'Appliances' started by ScotGooner, 14 Sep 2020.
  1. ScotGooner
    ScotGooner
    14 Sep 2020
    4
    Thanks Received:
    Country:
    Hi
    I've just bought this Panasonic bread maker and tried it out with the French recipe. What a disaster! Like a brick. I tried it with Allison's, Tesco's, and Dove's Farm yeast. I am using strong stoneground flour.
    I have used Panasonic for years (different machines) and the loaf has been poking out of the pan, until the last 18 months or more. Now the it doesn't want to know, even with the SD2511.
    I have made a basic loaf in a Morphy Richards bread maker which has filled the pan, therefore my simple mind says there's nothing wrong with the flour or yeast!
    Help anyone please!!
  2. Sponsored Links
    • Thanks Thanks x 1
    • Like Like x 1
  3. Notch7
    Notch7
    15 Sep 2017
    26,157
    Thanks Received:
    1,826
    S. Uplands
    Country:
    Im not sure, usually for me any disasters have been due to old yeast.
    is it white or wholemeal flour?
    what hydration level are you using? -maybe there's too much water
    if you are used to bread machines I presume you are keeping the yeast and salt separate?
    have you made a loaf with that same flour in another machine? -I ask just in case its actually ordinary flour not strong.
  4. ScotGooner
    ScotGooner
    14 Sep 2020
    4
    Thanks Received:
    Country:
    I followed the recipe exactly, the same as I have for years. I am using white strong flour.
    This is a brand new machine and I eventually had the same problem with an older one, after many years.
    The Morphy Richards machine makes perfect bread, so it surely cannot be the flour or yeast. I am totally confused
  5. Notch7
    Notch7
    15 Sep 2017
    26,157
    Thanks Received:
    1,826
    S. Uplands
    Country:
    I use a Panasonic SD-ZX2522KXC Bread Maker, I had it for about 3 years, I cant say Ive had any problems with it.
    It could be a faulty machine, is it mixing the stuff properly?
  6. Sponsored Links
  7. ScotGooner
    ScotGooner
    14 Sep 2020
    4
    Thanks Received:
    Country:
    As far as I know although even a basic white isn't as fluffy as it should be.
  8. Mottie
    Mottie
    27 Feb 2017
    19,580
    Thanks Received:
    1,955
    Essexshire
    Country:
    You are using the full bake menu aren’t you, not the quick bake? Try some new yeast.
  9. ScotGooner
    ScotGooner
    14 Sep 2020
    4
    Thanks Received:
    Country:
    There is only one menu for a French, number 9. As I said at first, I have used 3 different yeasts. Up until about 18 months ago, using a different Panasonic model, the loaf was climbing out of the pan, now it only gets half way in the old model and this brand new one as well.
  10. wig
    wig
    14 Jun 2006
    33
    Thanks Received:
    PONTYPRIDD
    Country:
  11. EightyTwo
    EightyTwo
    14 Feb 2012
    1,136
    Thanks Received:
    170
    Cambridgeshire
    Country:
    @ScotGooner Same symptoms as I had - won't cook a wholemeal loaf except on 'Rapid'... Change the capacitor (it takes a while!) from the thread that EddieM posted.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
