- Joined
- 22 Jan 2017
- Messages
- 4
- Reaction score
- 0
- Country
Hello, I'm new here and I wonder if anyone can help me with this please?
My daughter recently has an application for a part one/two storey extension refused for the reason –
‘The proposal does not comply with the Council’s requirement for a minimum 1 metre side space to be maintained to the flank boundary in respect of a two-storey development in the absence of which would constitute a cramped form of development…’
The relevant policy reads –
(i) for a proposal of two or more storeys in height, a minimum 1 metre space from the side boundary of the site should be retained for the full height and length of the flank wall of the building; or
(ii) where higher standards of separation already exist within residential areas, proposals will be expected to provide a more generous side space. This will be the case on some corner properties.
To explain, the house is on a corner plot and the one-storey part of the proposed extension is 0.3m to the flank boundary and the two-storey part is 2m.
So, on the face of it, this proposal does not meet the aims and objectives of the UDP, hence, its refusal seems correct.
However, the Council will allow separate applications for a two-storey extension with a 2m side space and a one-storey extension with a 0.3m side space (even where the two-storey part is 1m back), which means that the refusal was based upon a strict adherence to the wording of the policy; and not necessarily the aims and objectives behind it, which should read –
(i) for a proposal of two or more storeys in height, a minimum 1 metre space from the side boundary of the site should be retained for the full height and length of the two-storey flank wall of the building; or
My question is – could the Council have used discretion in interpreting the policy to approve this application?
If the answer is NO, it means that every similar application would require 2 sets of architects drawings, 2 application fees and 2 lots of waiting 8 weeks for approval – OR would it be possible to save 8 weeks at least by lodging both applications at the same time?
Thank you for your time.
