"Full of" does not mean "Everything". Anyway, some detail:The whole page is rubbish, it it?I got no further than the first page. It's rubbish! It's full of b'locks and errors.
Each of the 9 paragraphs are full of b'locks and errors, are they?
"on January 1st, 2003 the tolerance levels will be widened to +/- 10%." They were not.
"Supply Companies are not intending to reduce their voltages in the near future. This is hardly surprising, because such action would immediately reduce the energy used by consumers (and the income of the Companies) by more than 8%."
The author is confusing energy and power. Reducing the voltage will reduce power which is what the CEGB used to do to reduce demand (i.e. brownout) to try to avoid power cuts. Reducing the voltage will not reduce energy by anything like 8%; if it did, Vphase's energy saving con wouldn't be a con.
"In view of the fact that there will be no change to the actual voltage applied to installations, it has been decided not to make changes to the calculations in this book. All are based on the 240/415V supply voltages which have applied for many years and will continue so to do."
Here the author confuses the nominal or declared voltage with the average or typical voltage of a consumer's supply. Keeping the supply voltage for all consumers on a feeder within the tolerance based on the nominal voltage means that the average voltage must be above the nominal 230V. Indeed in theory, at the end of the feeder, where a consumer receives supply at 253V once a year and 216V once a year, his average voltage would be 243V.
Tables in BS7671 will have been based on 230V, so by using 240V instead of 230V in calculations the author will get the wrong answers.
"it is to be expected that manufacturers will supply appliances rated at 230 V for use in the UK. When they do so, there will be problems"
Why should there be problems when manufacturers should be designing equipment to operate within the voltage tolerance? (i.e. 205V to 253V for non-lighting products).
"High pressure sodium and metal halide lamps will show a significant change in colour output when run at higher voltage than their rating, and rechargeable batteries in 230V rated emergency lighting luminaires will overheat and suffer drastic life reductions when fed at 240V"
If the charging circuit for batteries can't tolerate a 4% voltage increase, it will be even worse with a 10% increase. But chargers don't work like that. They provide the correct charging parameters whatever the supply voltage providing it's within the permitted tolerance. Similarly for lighting controllers.
