Patio Paint
Thanks Zampa! Have pressure washed it this weekend so will get the paint out next dry weekend!
Karen :D
Thinking of painting my concrete patio and saw your posting. Looks good but I see that you did it about 18 months go - did it last?
Will we ever know :?: Has it lasted :?: Was it worth it :?: Did it mark easily :?: Did the frost get at it :?: Any moss :?:
What's under the patio :shock: :shock: :shock:
Is it still staggering :?:
Who was under the patio :?:
Mine lasted about 5 years before I needed to repaint it...but I put decking down instead..it should be fine as long as there are no puddles etc.
What was the "Exact" name of the paint you used?
Just come over, all.. Third_degree there :wink:
Rob,
I have a patio the same ghastly pink and cream colour that you had. Ive been trying to track down Ronseals Patio Paint to no avail.
So we are going to try the Crown Stronghold paint. Can you tell me what you thinned it will, was it just water for the first coat?
Also when we moved into the house, the patio had been laid badly by the previous owners and water tends to sit in puddles in various places.....if it does start to peel can we brush the loose stuff with a wire brush and retouch?
Any advice gratefully received!
Kelly.
Zampa, Can you help? I think it was actually you that used the Crown Stonghold?
Thanks,
Kelly.
I think it was stronghold but to be honest any of the branded masonry paints should do a job for you.
Better still use the pliolite based ones...thin the first coat by about 20% then do a full coat for the second one.
The only concern i have is that you mentioned 'puddles'...it wont last that well if its underwater for longish periods...you might have to do a bit of re touching here and there
hi there
I've been surfing the net looking for solutions to my drab looking patio and found your posting - with pictures that could be taken of my own garden.
Can I ask what paint you ended up using and whether it still looks as nice today?
many thanks
Jo
Hi there
The slabs on our patio looked very much like the "before" photo by an earlier poster before we painted them with Ronseal Patio Paint in April 2007. Just over a a year later, the paint has has lifted completely from a number of the slabs and partially from others, leaving a very unsightly area. I contacted Ronseal for their advice but they have been less than helpful. They say to treat it with an appropriate product, but go on to say they do not have an appropriate product and to find one ourselves. We are not regular DIY-ers and really don't have a clue where to go from here to cover the even more unsightly slabs, and cannot afford to replace the patio meantime. Your advice would be very welcome. Many thanks.
