PC not keeping up
18 Apr 2007
My PC started an irritating habit. When in word or e-mail, you type some words and they don’t appear on the screen. It’s like the PC thinking about processing what you put.
Then about 10 seconds later only half of what you type appears and the PC bleeps. Do you know what this could be, is it something to do with RAM? It’s just I am a fast typer & it’s getting annoying having to stop and keep going back.
This could be a few things to be honest. What's the spec of the machine you are using? What other applications are running at the same time (any virus scanners etc?)?
Something is chewing the processor. press ctrl alt delete and start task manager to see what's slugging the CPU.
I am having the same problem.
I've pressed control,alt/delete and started the task manager, but to be honest I'm not sure what I'm looking for.
This typed quite satisfactory but seems to get worse as the day goes on.
Any help appreciated
P.S I have anti-virus and anti-spyware in place as I thought I might be getting a bug?
After starting task manager, click on the "Processors" tab. then on the CPU column once or twice to sort them into usage order, highest at the top.
Tell us what the top few are, and what %age of CPU they are using.
Then click on the "Mem Usage Column" and tell us what the top few are, and what mem they are using.
Also tell us what Antivirus, Antispam and Antspyware packages you use, when you last ran them, and when you last cleared out your internet cache.
Depending upon which version of Word you have installed:
In Word, check under Tools/Preferences/Save to make sure that the Allow Fast Saves feature is NOT checked.
If Word in 2003, Tools > Options > Save tab and make sure that the Allow Fast Saves feature is NOT checked.
dave
Hi JohnD and Dave M
Thanks for your helpful advice.
First Dave M . I have checked Word 2003 and no the "allow fast saves box is not checked.
Onto JohnD I checked CPU in Task manager as you suggest. It keeps dodging about but appears as follows:-
System SYSTEM 98
explorer.exe Leslie 02
Ms Mp Eng. exe SYSTEM 90
System Idle process 07
In CD srv.exe SYSTEM 01
MEM Usage
System SYSTEM 51492K
Ms Mp Eng.exe SYSTEM 38156K
Skype.exe Leslie 31240K
avgrsx.exe SYSTEM 51492K
svehost exe. SYSTEM27484K
I have AntiSpyWare Bot.
Windows defender
AVG Antivirus
Threatfire
PC Tools Firewall Plus
Hope this helps
Kind regards
Les
my "System SYSTEM" runs at 0 CPU 252K Mem
so I don't know what is going on with yours as it is so high, but hopefully someone else will. If it was one of the things I recognise I might have had some suggs. Do you know if "Fastfind" is turned off? I remember it used to keep one of my machines busy, but I tuned it off long ago. I'm sorry I can't remember how.
good luck!
Hi JohnD
Thanks for trying to help
Is it possible I have too many anti spyware and anti virus running?
Also what did you mean when you asked when I last cleared out my internet cache?
How do you do that?
Kind Regards
from IE
tools
internet options
general
browsing history
delete
(my Norton Systemworks does cleanup for me a different way)
When did you last run updates and scans with your spyware/virus packages?
My updates and Anti-Virus are updated regularly.
In Delete browsing history I get a choice
boxes ticked are:-
preserve favourite website data
temporary internet files
cookies
history
Boxes not ticked are:-
form data
passwords
InPrivate filtering data
Do I now click the delete button at the bottom?
Download Hijackthis from here. Download the executable to your desktop and run it. Click "Do a system scan and save log file" and when the notepad opens up copy and paste all of it on here. Dont do anything else with it.
Hello daozen
I'done as you suggest, result h/w:-
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 19:12:51, on 25/09/2009
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\Program Files\Windows Defender\MsMpEng.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
C:\Program Files\Nero\Nero 7\InCD\InCDsrv.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\Program Files\Common Files\LightScribe\LSSrvc.exe
C:\Program Files\Common Files\LogiShrd\LVCOMSER\LVComSer.exe
C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\WINDOWS\Explorer.EXE
C:\Program Files\PC Tools Firewall Plus\FWService.exe
C:\Program Files\CyberLink\Shared Files\RichVideo.exe
C:\Program Files\ThreatFire\TFService.exe
C:\PROGRA~1\AVG\AVG8\avgemc.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\PROGRA~1\AVG\AVG8\avgnsx.exe
C:\PROGRA~1\AVG\AVG8\avgtray.exe
C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
C:\Program Files\Nero\Nero 7\InCD\NBHGui.exe
C:\Program Files\Nero\Nero 7\InCD\InCD.exe
C:\Program Files\ThreatFire\TFTray.exe
C:\Program Files\PC Tools Firewall Plus\FirewallGUI.exe
C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_S10IC2.EXE
C:\Program Files\ZyXEL\ZyXEL USB ADSL\CnxDslTb.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\Program Files\Common Files\LogiShrd\LComMgr\Communications_Helper.exe
C:\Program Files\Logitech\QuickCam\Quickcam.exe
C:\Program Files\Windows Defender\MSASCui.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Common Files\LightScribe\LightScribeControlPanel.exe
C:\Program Files\AVG\AVG8\avgcsrvx.exe
C:\Program Files\Microsoft ActiveSync\Wcescomm.exe
C:\Program Files\Messenger\msmsgs.exe
C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATIEFE.EXE
C:\Program Files\Skype\Phone\Skype.exe
C:\Program Files\AntispywareBot\AntispywareBot.exe
C:\PROGRA~1\MI3AA1~1\rapimgr.exe
C:\Program Files\Logitech\Desktop Messenger\8876480\Program\LogitechDesktopMessenger.exe
C:\Program Files\OpenOffice.org 3\program\soffice.exe
C:\Program Files\OpenOffice.org 3\program\soffice.bin
C:\WINDOWS\System32\alg.exe
C:\Program Files\Common Files\Logishrd\LQCVFX\COCIManager.exe
C:\Program Files\Skype\Plugin Manager\skypePM.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Program Files\Skype\Toolbars\Shared\SkypeNames.exe
C:\Documents and Settings\Leslie\Desktop\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://uk.msn.com/
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.co.uk/webhp?sourceid=navclient&ie=UTF-8
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page =
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Skype add-on (mastermind) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.2.4204.1700\swg.dll
O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_B7C5AC242193BB3E.dll
O2 - BHO: MSN Toolbar Helper - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - C:\Program Files\MSN\Toolbar\3.0.1203.0\msneshellx.dll
O2 - BHO: TBSB00982 - {DA3D342F-FF20-4E31-9E82-22334155730C} - C:\Program Files\Antbar\Ant.com Toolbar\tbcore3.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O2 - BHO: EpsonToolBandKicker Class - {E99421FB-68DD-40F0-B4AC-B7027CAE2F1A} - C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll
O3 - Toolbar: MSN Toolbar - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - C:\Program Files\MSN\Toolbar\3.0.1203.0\msneshellx.dll
O3 - Toolbar: EPSON Web-To-Page - {EE5D279F-081B-4404-994D-C6B60AAEBA6D} - C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll
O3 - Toolbar: Ant.com Toolbar - {6CD56C02-CB4D-41B5-A0FE-B479061CCB41} - C:\Program Files\Antbar\Ant.com Toolbar\tbcore3.dll
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
O4 - HKLM\..\Run: [LanguageShortcut] "C:\Program Files\CyberLink\PowerDVD\Language\Language.exe"
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [SecurDisc] C:\Program Files\Nero\Nero 7\InCD\NBHGui.exe
O4 - HKLM\..\Run: [InCD] C:\Program Files\Nero\Nero 7\InCD\InCD.exe
O4 - HKLM\..\Run: [ThreatFire] C:\Program Files\ThreatFire\TFTray.exe
O4 - HKLM\..\Run: [00PCTFW] "C:\Program Files\PC Tools Firewall Plus\FirewallGUI.exe" -s
O4 - HKLM\..\Run: [EPSON Stylus C64 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_S10IC2.EXE /P23 "EPSON Stylus C64 Series" /O6 "USB001" /M "Stylus C64"
O4 - HKLM\..\Run: [CnxDslTaskBar] "C:\Program Files\ZyXEL\ZyXEL USB ADSL\CnxDslTb.exe" "ZyXEL\ZyXEL USB ADSL"
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [LogitechCommunicationsManager] "C:\Program Files\Common Files\LogiShrd\LComMgr\Communications_Helper.exe"
O4 - HKLM\..\Run: [LogitechQuickCamRibbon] "C:\Program Files\Logitech\QuickCam\Quickcam.exe" /hide
O4 - HKLM\..\Run: [Windows Defender] "C:\Program Files\Windows Defender\MSASCui.exe" -hide
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [LightScribe Control Panel] C:\Program Files\Common Files\LightScribe\LightScribeControlPanel.exe -hidden
O4 - HKCU\..\Run: [H/PC Connection Agent] "C:\Program Files\Microsoft ActiveSync\Wcescomm.exe"
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [EPSON Stylus SX200 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATIEFE.EXE /FU "C:\WINDOWS\TEMP\E_SC0.tmp" /EF "HKCU"
O4 - HKCU\..\Run: [Skype] "C:\Program Files\Skype\Phone\Skype.exe" /nosplash /minimized
O4 - HKCU\..\Run: [swg] "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
O4 - HKCU\..\Run: [AntispywareBot] C:\Program Files\AntispywareBot\AntispywareBot.exe -boot
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O4 - S-1-5-18 Startup: OpenOffice.org 3.1.lnk = C:\Program Files\OpenOffice.org 3\program\quickstart.exe (User 'SYSTEM')
O4 - .DEFAULT Startup: OpenOffice.org 3.1.lnk = C:\Program Files\OpenOffice.org 3\program\quickstart.exe (User 'Default user')
O4 - Startup: OpenOffice.org 3.1.lnk = C:\Program Files\OpenOffice.org 3\program\quickstart.exe
O4 - Global Startup: Logitech Desktop Messenger.lnk = C:\Program Files\Logitech\Desktop Messenger\8876480\Program\LogitechDesktopMessenger.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
O9 - Extra button: (no name) - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
O9 - Extra 'Tools' menuitem: Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
O9 - Extra button: (no name) - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra 'Tools' menuitem: Skype add-on for Internet Explorer - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {4E62C4DE-627D-4604-B157-4B7D6B09F02E} (Egg Money Manager Digital Safe) - https://moneymanager.egg.com/Pinsafe/accounttracking.cab
O16 - DPF: {C1FDEE68-98D5-4F42-A4DD-D0BECF5077EB} (EPUImageControl Class) - http://tools.ebayimg.com/eps/wl/activex/eBay_Enhanced_Picture_Control_v1-0-27-0.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/flashplayer/current/swflash.cab
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} (get_atlcom Class) - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{BE4A4941-526A-42CB-919C-705E6848AD66}: NameServer = 62.24.139.140 62.24.139.139
O18 - Protocol: bwfile-8876480 - {9462A756-7B47-47BC-8C80-C34B9B80B32B} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\GAPlugProtocol-8876480.dll
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\COMMON~1\Skype\SKYPE4~1.DLL
O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\SYSTEM32\avgrsstx.dll
O23 - Service: AVG Free8 E-mail Scanner (avg8emc) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgemc.exe
O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: InCD Helper (InCDsrv) - Nero AG - C:\Program Files\Nero\Nero 7\InCD\InCDsrv.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: LVCOMSer - Logitech Inc. - C:\Program Files\Common Files\LogiShrd\LVCOMSER\LVComSer.exe
O23 - Service: Process Monitor (LVPrcSrv) - Logitech Inc. - C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
O23 - Service: PC Tools Firewall Plus (PCToolsFirewallPlus) - PC Tools - C:\Program Files\PC Tools Firewall Plus\FWService.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exe
O23 - Service: ThreatFire - PC Tools - C:\Program Files\ThreatFire\TFService.exe
End of file - 12593 bytes
