Use a decent brand of calibrated ratchet crimping pliers, strip the correct amount of wire sheath back, thread into the crimp ensuring all strands are inside the crimp tube, put the crimping pliers onto the crimp in the correct area using the correct colour coded die, observing if the pliers need to be used the correct way around and sqeeze till the crimping pliers are allowed to release.
