Not sure if you can still get them, but there was a sort of resin filled plastic pot at one time, i think it was yellow and i think you squeezed it on with pliers
Try glancing after the fire.At first glance hard to tell between Ali-tube and MICC.
Pyro was great if you want a really neat install. It can look good across an old stone wall. I've never used the covered stuff only the bare copper, used to use a blowlamp to dry it out if the ends were damp before the pots were put on.
No, to see if my handiwork has held up for 40+ years!For the scrap copper?
Insulation tests this evening all show >2000MΩ at 1KV DC
The fire at Hampton Court Palace was around the mid-eighties so I presume since then NT has used MICC to guard against fire in old buildings, if they weren't already doing it. Many fires in old buildings are attributed to electrical faults...Windsor Castle obviously missed the upgrade until its own fire in the early '90s.It's also used in National Trust rewires.
I seem to remember it was a spotlight too close to a curtain.Wasn't the Windsor fire started by a dozy plumber with a torch? Or painter with a hot-air gun? I know that there has been a high-profile fire which was caused that way.
