PILOT LIGHT
9 Jan 2007
I TURN THE PILOT LIGHT ON MANUALLY AND EVERYTHING WORKS FOR 10 TO 20 SECONDS.
THEN THE PILOT LIGHT GOES OUT AND TRIPS THE ELECTRIC IN THE HOUSE
images
Great... A Quiz Post! I love a quiz!
Right then, is it a Book, Film or TV? :D
I will guess that there is a water leak in your boiler, and water is dripping onto an electrical part and causing a fault to earth which trips your RCD.
My second guess is that there is a water leak in the circulating pump causing a fault to earth which trips your RCD.
I will wager £10 that the fault is not the pilot light.
I think you need a boiler engineer.
What prize are you offering for the first correct answer?
p.s. the link Sluggy posted is to some advice headed "before you ask a question please read this." Click on the blue word "this" in his first reply.
My guess is that there is a power supply close to the gas valve solenoid . When the boiler tries to fire there is some RF [spurious radio frequency emmissions] coming from the solenoid which is picked up by an RCD turning the power off. At the same time the RF surge is enough to disturb the field coil [connected to the thermocouple] inside the gas valve causing it to let go of the pilot valve thus shutting off the pilot as well.
If I am right then your gas valve is probably cream crackered or at least needs a condenser fitting to suppress RF.
Are ya taking bets kev or what?
I'll have ten bob on me :wink:
If we knew what the boiler was and it has a 240 gas valve theres a good chance that the RF was shooting back through the supply and tripping the rcd that way.
Getting a less sensitive RCD will stop the power going off but not the pilot going out
