I've just acquired one of those pipe benders which forms the pipe over a curve to try and achieve some nice bends. I've just had a play on some 15mm copper and it deformed the profile quite significantly - flattening the outer surface where the roller pressed against the pipe and causing "ripples" on the curve inner surface. Is this usual for one of these tools?
The tool came supplied with 2-off 5" long straight radiused straight sections too, which are for 15 and 22mm pipe. With no instructions as to what they are used for?
Can anyone provide some help on the use of this tool as it's cost me £30 and I would like to use its full potential.
