Whilst I'm on here asking questions...
I've been doing a bit of pipe work and my trusty old pipe cutters are both starting to spiral a bit on 22mm pipe - they seem fine on 15mm but the larger diameter of the 22mm is leading them to spiral a little.
Holding the pipe in my hand reduces this but doing a tricky cut under the floorboards was nearly impossible.
Both are small cutters, one smaller than the other.
One is a Monument Size 0 and the other is a Record 200-22.
Is it likely that they just need replacement wheels? The monument feels to have a fair bit of side to side play from the wheel holder (is that normal?)
I guess basically I'm asking am I better to just buy a replacement wheel from ebay for these or am I better to just buy a new cutter?
Also do you just drift the axle out on the monument as it doesn't have a screw head like the record.
If I should buy a new cutter - do you have any recommendations?
