I plan to move my bathroom basin from the outside wall to the opposite wall. How may bends can I have in the pipe run?
looking at the basin the pipe run will be, from basin, left 45cm , 90deg bend, 70cm, 90deg bend 110cm, 90deg bend 170cm, 90deg bend 150cm to stack. would this be ok.
or I could cut a channel the concrete floor for a straight pipe run. If I did this how for much concrete would I need above the pipe. Floor will be tiled.
What the are pipe gradients for 32mm , 40mm 50mm pipes. Is it ok to use 40mm for a shower.
