pipe touching 1.0 cable
9 Apr 2006
Nottinghamshire
Hi, I'm a little concerned about a wire to a switch in a pipe box. The cable is 1.0 and is touching the radiator pipe. Should it be moved? is there something I can put between the pipe and cable?
TIA
You could also usefully fit some pipe insulation using the long foam sleeves. Don't use expanded polystyrene as it attacks PVC cable.
