    Dismiss Notice
Pipework for fridge water dispenser?
Discussion in 'Plumbing and Central Heating' started by GaryMo, 8 Apr 2020.
  1. GaryMo
    GaryMo
    3 Jul 2007
    4,130
    Thanks Received:
    162
    Manchester
    Country:
    I’m slowly working my way though my kitchen and am considering a future fridge/freezer with a water dispenser so would like to install pipework should we choose to have one.
    What would normally be expected for connection? Would a 10mm JG speedfit with an angle and stop connected to the cold water feed be sufficient or is there something more specific required?
  2. flameport
    flameport
    10 Mar 2007
    8,729
    Thanks Received:
    1,648
    Poole, Dorset
    Country:
    Double check valve and a 3/4" washing machine valve.
    • Thanks Thanks x 1
  3. GaryMo
    GaryMo
    3 Jul 2007
    4,130
    Thanks Received:
    162
    Manchester
    Country:
    That’s the termination, so a 10mm pipe would suffice?
    Thanks.
  4. denso13
    denso13
    22 Jan 2007
    3,064
    Thanks Received:
    655
    Country:
    Yes
    • Thanks Thanks x 1
  5. Sponsored Links
  6. bobasd
    bobasd
    2 Dec 2017
    2,373
    Thanks Received:
    399
    Country:
    Leave a loop of the supply pipe behind the F/F - enough to pull the appliance out. Similar to a gas hose behind a cooker.
    • Thanks Thanks x 1
  7. GaryMo
    GaryMo
    3 Jul 2007
    4,130
    Thanks Received:
    162
    Manchester
    Country:
    Thanks, all very helpful.
  8. Nige F
    Nige F
    28 Jun 2005
    20,358
    Thanks Received:
    1,558
    Country:
    The one we had came with a long flexible pipe - On the appliance - no need for 10mm speedfit flapping about(y)
    • Thanks Thanks x 1
    • Like Like x 1
  9. Madrab
    Madrab
    4 Oct 2012
    6,264
    Thanks Received:
    1,643
    East Renfrewshire
    Country:
    Yup, it will probably come with a filter, that will be fitted to the wall behind the FF or on the back of it, and a small 5mm plastic pipe will run from that to an adapter that will fit on a 3/4" appliance valve. Some also come with a separate valve. A 10mm supply pipe will be fine but you'll need to use a reducer to fit an appliance valve to that. Easier just doing it in 15mm IMO.
    [​IMG]
    • Like Like x 2
    • Thanks Thanks x 1
Loading...
Share This Page
