clf-gas said:But Armaflex is insulation not protection
Your house must be a sight too see
amateurs know best![]()
It is protection.
And it also prevents heat loss to the screed.
Gasguru said:Hairfelt lagging (for expansion as well) and then 50mm PVC tape with overwrap if its within the heated space.
billybez said:am about to pipe in new rads in extension, pipework is to be covered with concrete screed. Can i do this in copper wrapped in denzo tape or do regs say it has to be plastic in conduit ?? any ideas.
cowboyplumber said:Denso tape is no longer allowed on gas pipes in screed.
I would be inclined to try and find or create another route or re-arrange the system so that you dont need to go under the floor.
If there was no other option I would exceed any requirement and prefer treating the pipework as though it was a gas or potable water pipe with a ducting and some form of access in case anything went wrong.
The least I would settle for with a disclaimer is to use a plastic pipe with no joins in it and run this through a larger pipe as a sheath to allow for expansion, contraction and any movement in the floor.
Granted that under floor heating systems use plastic pipe in the screed but these are restricted to 50ºC to avoid
Some are piped in at full boiler temp
using certain types of valves.
clf-gas said:Some are piped in at full boiler temp
Which is?.
Which are?.
I'am very interested to know, and always willing to learn.
Maybe your next post could actually aid the OP.![]()
Balenza said:clf-gas said:Some are piped in at full boiler temp
Which is?.
Which are?.
You have a short span of attention clf.
Sand and cement screeds are semi dry
They used to think that about polystyrene fill that they used for wall insulation. Years down the line they have degraded and can sap water and damage wallsThe closed-cell structure of AP/Armaflex prevents moisture from wicking
It isn't a 'normally' when the dpm fails or there is another source of moisture such as an undetected leaking rad valveAP/Armaflex normally requires no supplemental vapor-retarder protection.
If you walked into a new build of mine
It ain't bodging! Its called using your brain to come up with a better solution.
Anything is better than running any pipe through a concrete floor. Copper and concrete don't mix.
.There is nothing wrong in exceeding any requirement
It's only when requirements are not met and common sense is not used that you get problems. To draw a parrallel. Common sense tells you not to fit electrical sockets under a sink unit where they may get wet yet there is apparently no law or guidance saying otherwise.
Running pipes in walls beats running pipes in ground level or concrete floors IMO.
People have habits of spending lots of money on floor coverings tiles hardwoods and laminates etc. On the occasions when you do get a leak; the ones under floors are the worst to deal with.
Talking now specifically of using copper in armaflex insulation
If thats true then it also means that they are semi wet
Ah now I see where your opinions come from.
If you spend some time on repairs and maintenance you will see all the time bombs that have been created by new build workers in the past.
Perhaps you have never had the privilege of telling someone that has just spent a load of money getting their whole ground floor covered in expensive tiles or wood that somewhere underneath it there is a leak. The most competent plumbers have been sold a faulty fitting and pipes have split due to impurities or mechanical damage. I can cite loads of instances but dont wish to spend a week writing about it.
ChrisR said:What do you do at the joins in the insulation and elbows under rad tails, if not Denso tape? (Or inspection arrangements)
Given that there's never one universally best method to do anything, and given that some people successfully use Denzo and tape, and some other people successfully use tubular foam insulation, can you explain exactly what you mean by "bodging"?Balenza said:It is bodging. If thats the best you can come up with you wouldnt get near my place.Slugbabydotcom said:It ain't bodging! Its called using your brain to come up with a better solution.
