I 4 toilets which run off one single ducted fan in the top of the building. What I want to do is put occupancy sensors in all the toilets so when someone enters the lights go on only in that toilet and so does the common fan, all for a pre set time. If I use normal PIRs would I be right in saying that if I walked in one toilet it would work as above but also the lights in all the other toilets would go on as well?
Is there such thing as a PIR with 2 outputs? If so where? Failing that the only other solution I can think of is using 2 PIRs in each toilet which seems a little overkill and expensive.
Any ideas please?
Neil
Any ideas please?
Neil
