Is it okay to use standard plasterboard as a ceiling in a bathroom? It will be skimmed and then painted (probably with some sort of bathroom emulsion.)
What effect am I trying to achieve? Is it for thermal insulation or for moisture reduction? The new boards will be below the original ceiling as mentioned, and then above that there is 200mm of insulation and then the loft floor.
