please look
12 Apr 2004
Hello, I would like some help with a few things. I would be most grateful if someone could add me to MSN Messenger and spare mins of their time.
I feel rather stupid asking for help but it's the only way i can understand and learn.
thanks
Harry
what is it you want to know?
by asking on here everyone can add their tuppence worth
ok,
how would i fit a conduit extension arm to the wall to connect a v.d.u. visual display unit?
what is the procedure for correct alignment and positioning of the v.d.u. extension arm?
i dont quite understand this.. it sounds simple how ever i've never comes across this scenario
cheers
Harry
*spelling*
no, i just have no practical experience.
so help would be greatful.
i think you should clarify what you are refeing to by a "conduit extension arm to the wall "
with the aid of diagrams, describe the fixing methods to be used for fixing the extension arm to the wall, for the 30kg v.d.u.
b) explain the process for correct alignment and positioning of the v.d.u. extension arm.
thats all i have to work with.
do i use a T junction box and have an extension running off of it?
to i have a running cuppler to fix it into the v.d.u.?
would be greatful if you could give me some ideas and point me in the right direction.
thanks
Well, the only help I can offer on this one is with b) correct alignment.
The screen needs to be directly in front of the user, no sitting looking at an angle at the screen (although many shop-bought desks force you to look to one side).
The top of the screen should be level with the eyes of the user when sitting up straight (assuming they sit up straight of course!).
The screen should be 2 feet from the eyes of the user.
My company periodically checks all of our workstations to make sure we are set up correctly (avoids people taking time off with bad backs and sore-eyes, cheap solution!) so being a hypochondriac I have all the blurb memorised :wink:
I got so annoyed at the quality and dimensions of shop bought desks that I ended up building my own for home, ergonomically designed entirely to my dimensions and it is great.
Harry, have you not considered a flat panel display? 30Kg!! Sheesh, you will need one decent wall and some serious fixings for that sort of weight.
Do you realise that the actual stress weight of the arm, assuming a 400mm arm length, is actually over 60Kg per fixing..You cannot mount this in a stud wall or a breeze block wall, they simply will not take the mechanical loading.
Lol Harry, would you rather one of us sat your exam for you instead of having to help you answer the whole of the paper?
I agree with FWL_Engineer 30kg is very heavy, concidering the maximim you can handle is 25kg! by yourself.
I also agree with AdamW about the positioning, however the question is more intrested in how it is to be installed correctly
this is a question from the second assignment Harry Lee??
anyway a bit of help.
a)mension use of rawbolts etc and an indication that the load bearing has been taken into account.
appropiate methods bearing in mind the aesthetic effect.
b) For allignment mension the correct use of spirit levels? plumb bomb etc.
hope this helps.
with a name like Carlos(s) please don't mention Bombs, ask Bob!
I completed an Electronic Engineering course last year.. Some of the 2360 were in the syllabus. Therefore i carried on with part 1 year 2 in the 2360 this year so i have been given year 1's assignments to complete.
kendor
It's Carl Actually :)
