How about me using a 16amp industrial socket and plug on a 32amp radial as they have shrouds around the pins as that would be safer than 13 amp plug or would that not be allowed either .
It comes with a plug, for plugging in. If you want to do something else then all of the other regulations would need to be looked at for kit without plugs. If you are allowed to remove the plug, would/should you also be allowed to add a plug to inverters that don't have them?
I suspect the regs are tight because it is just being introduced and that they will change fairly soon, for example, adding battery storage.
