I have always found this site absolutely fantastic for honest professional help, and I need it again please! (Pictures below to help out advice)
Basically my fathers friends friend is a plumber and he has just been round to give us his opinion and a quote.
This is our problem:
Basically the Hot water needs to be on for the central heating to work, we have a very modern control panel which allows both to operate independently how ever when you select just the CH then nothing happens.
This moves on to the other problem, that when just hot water is selected the system is silent, when you add in the CH and turn it on, as soon as it comes on the airing cupboard makes a woooshing sound and sounds like a kettle boiling for about 30 seconds. Then stops and everything is silent.
The plumber has said the following:
1) We need a new 3 way control valve as this is causing the above problem and this will resolve it. He suggested this one:
http://www.screwfix.com/p/honeywell-v4073a-3-port-motorised-valve/31421
2) He also advised that we should fit a new pump as ours was over 15 years old and this would make the system more efficent, he suggested this one:
http://www.screwfix.com/p/wilo-4132507-smart-central-heating-pump-a-rated/53435
3) Then he suggested while the system was drained to also fit a Fernox TF1 in between the three way valve and the pump, like this:
http://www.screwfix.com/p/fernox-tf1-total-filter-22mm/84311
4) He suggested fitting Automatic bleed valves to one ground floor and a first floor radiator as he said they make old systems more efficient.
5) Finally he suggested we change our bathroom radiator as he had noticed some corrosion and that single panel radiators only last for around 15 years, and it could be rusting from the inside and could soon cause a leak.
My questions are:
1) Are all his recommendations correct / advisable ?
2) Does it sound like the 3 way valve will fix the problem we have?
3) Will items 2 and 3 improve our system and make it more efficient?
4) Anything else?
Thank you in advance!
My questions are:
4) Anything else?
