Based on the second picture, the little black button is I think the later design which can be pressed to turn and remove the head.
As you have been told, the body may have a tight shaft causing it to stick. In that case its best to replace all of the valve.
However, that model is not very reliable and often the problem is just in the head.
If the head is removed, it should be possible to turn the shaft with your fingers. If thats the case then just the head can be changed.
Any competent heating engineer would check that before giving a price as changing the head is a simple job hence our lower price of just £144.
Tony
Tony
