Temper, temper - shouting will not change the fact that you did not ask about HIE. You asked the question of what colour I would use for the cpcs. You did not mention that it was specifically in relation to HIE or 543.7, so I answered what you wrote. Would you have preferred that I went looking for things you didn't write to add to the question ?Yes
I
did
Don't forget, you have been wittering on about "read what they actually say" - then complain when someone does that ?
Do you have a problem comprehending that statement ? It would appear that you do.So - just to clarify, you could give a truthful answer to the question "When did you stop beating your wife?", and it would be a simple answer to that simple question, i.e. it would be a date in the past, or a time interval between then and now, but you are choosing not to?Now that is clear for all to see - you are trying to make out that if I choose not to give an answer, then the only reason is that I can't answer. I've already said that I could give a simple answer, but I won't because it's none of your damn business;
But yes, I could give a simple answer, but that private matter is none of your damn business. Do you have a problem with personal information not being any of your business, or of anyone else here ?
Like I say, I'm pretty certain you would have much the same response to someone asking you personal information. Care to tell us where you work for example ? I assume the answer is that you could tell us, but you aren't going to - and I don't have a problem with that. Do you want to get back to a matter of opinions about the subject, or carry on with this irrelevant sideline you introduced ?
And therein lies the fundamental problem.543.7.1.203(iii) requires two individual CPCs.
543.7.1.203(iii) requires that each of those two individual CPCs comply with Section 543.
543.2.9 requires that the CPCs of ring circuits be rings themselves.
Therefore the two individual CPCs required by 543.7.1.203(iii) have to be two individual rings.
543.7.1.203(iii) does not refer to cpc, it refers to PE. PE is not the same as cpc. 3.2.9 refers to cpc, and therefore does not apply to the two circuits referred to in 543.7.1.203(iii).
It's there in the regs for you to read - you do keep saying to read what they say don't you ?
Without trawing back through the thread to check, wasn't it you who wrote something along the lines of a lot of clever people wrote the regs, is there any reason to doubt that they meant what they wrote and what they wrote reflects what they mean ? I would have to assume that there's a reason they refer to cpc and PE where they do - or are you now saying they are wrong to do so ?
But here is my interpretation, and another diagram :
To my reading, 543.7.2.201(i) specifically states that A (singular) ring PE is acceptable.
I don't think that there is any doubt that that statement on it's own appears to be saying that other than the use of separate terminations, a standard RFC with a ring cpc already complies.
For the purposes of 543.7.1.203(iii), a-A forms one PE (which is also part of the ring cpc), AA-BB-B-b forms another PE (which is also part of the ring cpc).
These together make a standard RFC comply with very minor modifications.
So I believe the argument comes down to : can the ring cpc also be those two separate PEs at the same time ? I do not believe that is incompatible with the definition of PE "A conductor used for some measure of protection against electric shock and intended for connecting together any of the following parts ..."
You can of course argue that you cannot consider part of the ring in isolation like that. Well that's fine, and I believe that is your position.
But, in this image :
does that argument not also mean that you do not have "two individual protective conductors".
So short of complying with 543.7.1.203(i) or (ii) you need an extra PE over and above that. That contradicts what you've stated in the past to be your belief - that linking the ends of radials like that complies.
