We are having the entire plumbing replaced, and the plumber is using polypipe (Polyplumb) for the central heating pipes. I don't have a problem with plastic pipes being used in place of copper pipes (we will have copper tails). But I am finding that many 'corners' are being cut. For example, where there is insulation on the pipes, under the downstairs floating floor, he has only used felt and no foam (okay, maybe this is just a difference of opinion on felt vs form). He does not seem to have used many clips (actually I'm yet to find one!).
I've just read that pipe stiffeners are part of the Polyplumb system, and am sceptical that he has used these. How important are they? Is this something easy for me to check, and is it worth insisting that they are used? (I am having to pick my fights … so is this one worth it?)
http://www.polypipe.com/sites/default/files/Polypipe_Installation_Guide_PolyPlumb_web.pdf
"Step 2: Use of pipe stiffener Insert a pipe stiffener into the pipe (not required on copper pipe). Pipe stiffeners are an integral part of the joint when using Polypipe grey pipe with either PolyPlumb fittings or compression fittings and need to be fully inserted in to the pipe end. Polypipe offer two types of pipe stiffener to be used with PolyPlumb fittings - metal and plastic. When using a pipe stiffener, ensure it is fully inserted before applying the fitting."
