What you're doing is the same thing. The time you have to wait for the water to come out(under gravity) depends on the configuration, and how much water there is to come out.
It sounds like one of your safety valves is leaking - ie letting water pass, below the pressure at which it's designed to. There are two and they will both widdle through the tundish. You can tell which by undoing the union (usually just a compression nut) on the valves and seeing which one is wet inside. If you twist the knob on the valve water will rush out and the valve will snap shut, which just might be all it needs.
Obviously this should still be covered by the warranty, so the installer's problem.
