Porcelain tile cutting
25 Mar 2008
Staffordshire
I am fitting a bathroom at the daughters house in Surrey
She has chosen one metre long porcelain tiles .
My biggest Rubi is 600 mm long and a wet saw about 700/800 long
Can I ask for your advice and recommendations for a cutter please ?
My mate is lending me his Rubi wet saw but again I don’t think it’s 1000 long
I hope the wall is flat! Had to do a rush tiling job at Son's house a while back. I said don't get Metros, and what did he get - Metros, and wanted brick bond! Cement was 15mm thick in the middle of the run trying to eliminate the lippage!
I don’t know why my daughter has chosen porcelain as I have said a million times to her , don’t get porcelain tiles lol
As you have probably suffered as well , after the tiles are up
Some poor so and so has to drill 20 odd holes for hanging various bits and pieces
A small 125mm grinder is all you need.
Handy tip :- When you come to drilling all those holes for hanging all the bits and bobs, use these ….
( 6mm std Spade/Arrowhead drill bits. £9 for 10 ) You’ll only get 1, maybe 2 holes per drill, but they do get through Porcelain no bother, and at less than a quid each….
A friend years ago showed me them, I’ve been using them ever since.
Cordless 125mm probably safer
Agreed, a 115 or 125mm grinder will be be easier to control.
I have only ever used a 9" when cutting 40mm deep sandstone floor tiles.
With the right set up, you should be able to use a smaller angle grinder within 0.5mm tolerances even over 1000mm (free hand).
I have seen people on the web that fit diamond blades to their track saws. I guess the downside is that the blade spins in the wrong direction and may chip the top face.
A few years ago, I did purchase a second hand plunge Festool angle grinder that runs on their tracks. Thus far I have only used it once and that was to cut a straight line in render where one house meets another. Lovely tool but when using the track, depth of cut is only 23mm. I haven't done any tiling since buying it...
