Potterton Boiler with Gunged pipes
9 Mar 2007
Glasgow
Hi, I wonder if anyone can give me some advise;
I have a Potterton Performa 24 which stopped working a few weeks ago after I bled a radiator.
Normally I reset the boiler inside and top up the water and it starts up again - but not this time.
I've had a company out and their now telling me that the pipes inside the boiler are all gunged up and this is why my boiler won't reset or work??
The system was checked in October and it was all OK.
The advise given is that I need to replace my boiler - is this my only sensible option???
They also can't tell me why this happened in the first place and more importantly how I prevent it happening again.
Any advise welcome , thnx
cos the lazy git that installed it didn't flush the system properly
no
get the system flushed (properly) then add inhibitor
Have you tried the reset button inside the boiler?
It won't reset, it usually works .
Looks like I need to get the system flushed, does that flushout the internal pipes in the boiler too?
Thanx
It sounds as if you have been resetting the o/h stat a lot of times.
This is a safety device and designed for engineer reset on the basis that the engineer has dealt with the problem. It has probably failed from excessive use!
Merely getting somebody to powerflush the system will not include dealing with the boiler. You need someone who understands the boiler and knows how to deal with the boiler as well as poweflushing the system.
The plate HE will also be pretty well blocked and will need to be included in the cleaning.
