Potterton Overtemp Tripping
8 Mar 2023
Morning all.
Can anyone help me with a bit of advice.
We “inherited“ a Potterton Prima 60F boiler (which we were told in 2013 was 3/4 years old). It turns out after checking Serial number with Potterton that it was manufactured in 2003.
Had it regularly serviced but a few weeks ago it failed to come on in the morning. I found the over temperature reset - pressed it and it restarted.
Failed several more times so the Service chap checked it over when he came and said he though that the flue was the problem.
Normally I have hot water and heating on from 7.00am to 9.00am and then hot water 4.00pm to 6.00pm with heating 4.00pm to 9.00pm.
I changed the timings and had hot water on 5.00am to 7.00am. Today, for example, hot water worked ok but no heating when we got up - had to reset again.
After service it has still continued to fail and the chap is currently looking to quote us for a replacement due to the age!
What I can’t understand is that it will work ok for a longish period then it will go off on the room stat but (now a couple of times a day) it has to be reset for it to restart.
Is there anything else anyone could suggest as to the cause of the problem? Could it be a faulty Boiler thermostat for example?
Any ideas would be welcome as sods law it’s happening on the coldest days of the year.
Kind Regards
David
Thanks “cross thread” I’ll have a look how much they are. Would you happen to know if you can test them or is it just a matter of replacing the current one to see if that then works?
kind regards
David
your boiler uses a Ranco stat , never seen a faulty one that can be reset, they are a liquid filled Phial and capillary tube, if the capillary was leaking you wouldnt be able to re-set it, you have a circulation problem
I would suggest it is probably a poor flow through the system, or the boiler, causing it to over-heat.
Room stat or overheat stat or both?
Hi Chris. It will cut off on the room stat as normal but then will not restart and I have to press the overtemp reset button. It then starts.
Does the boiler do a pump overrun after shut down? Some boilers had/have a separate overrun stat that keeps the circ pump running until the temperature falls, maybe this is the problem?.
Could be the overheat stat, but if @ianmcd has never seen a faulty one, then chances are it isn’t. Check for circulation issue as Ian states.
