- Joined
- 19 Jan 2005
- Messages
- 8
- Reaction score
- 0
- Country
Three and a half year old boiler which tends to turn itself off for no reason and requires frequent resetting.
A typical day - I have to reset the boiler each night before going to bed and after the timer has switched the system off - 11pm. 6am and the timer switches the system on, red light on permanently but green starts to flash as the system requires heat, fan comes on and 7-10 seconds later the boiler ignites. Boiler stays and after about 20 mins of it being on a buzzing sound is heard from below where the lights are for about 10 seconds. Varying amounts of minutes then pass and the boiler switches itself onto red flashing - off. Press reset button, boiler fires up and once heats water and rads up switches itself off, pump still running green light flashing slowly with red light on, green light flashes, fan comes on, sparky inside boiler starts sparking but buzzing sound from boiler for about 5 seconds - no ignition, boiler tries this three times and unsets itself. We have to reset it, but you can reset it after half a minute and it fires up with no buzzing sound at the first attempt. This goes on about 6-7 times a day and our plumber seems to think that its either the overheating thermostat, the sparker, gas valve or pcb! I only want to replace one bit, not all of them or else I might as well buy a new boiler by the time I pay for labour and vat!!!
Anybody with any ideas or same problem?
