Hi, I'm trying to find a saw I can use close in to a wall, I was wondering if anyone knows of a padsaw type tool that is powered ( preferably cordless)?, normal Jigsaws are tool bulky (wide) for this job.
A Fein Multimaster, or a (cheaper) Bosch PMF 180. The cordless Multimaster is quite a pricey tool (around £285). A post in this thread says Bosch are introducing a cordless version of their tool soon.
The Bosch looks like the best option of these for the application, As far as I can work out these work by oscillating the blade. How good are the at cutting skirting and the like. I imagine it eats plasterboard no prob. anyone used one ?
They work really well as long as the material being cut is firm. If the material can move even a tiny bit ( a door or a copper pipe on the wall) , then it will oscillate along with the blade and the cut takes much, much longer
