Power Shower Pump
13 Apr 2007
Essex
Hi, just a quick question.
As I know and understand, any electrical work in a bathroom and kitchen is prohibited under part P.
But if the power shower pump is located in an airing cuboard or loft space and therefore outside of the bathroom.. and as far as I know.. but could be wrong, part P states 1 socket can be added to 1 circuit.
can I legally install a shower pump.
I know things like an electric shower, shaver sockets are prohibited so I cant install those.
But what about a 12v low voltage extractor fan?.. as the electrics would be in the loft space, and what is in the bathroom side inside the fan is low voltage... my initial thought was that was also included under Part P... and cannot be installed, but I just wanted confirmation.
You could extend/alter an existing circuit to add a shower pump outside the bathroom without need for notification. Not sure where you got the one socket/circuit idea from, but there is no arbitrary limit to the amount of additions or alterations you are permitted to make.
As stupid as it is, you could install a ducted fan in the loft with the vent grille in the bathroom, but you can't actually install the fan itself in the bathroom. That is, assuming you don't have to open the bathroom light fitting and pick up a supply from there.
Hi, was just something I read before.. by socket I know it can include spur etc.. so I probably should of said 1 extension/alteration per circuit
didnt realise there was no limit on it, thought you could only add 1 addition be it socket/fcu/light then any more and the circuits would need testing and notifying.
but i just found this,
Q5: What types of electrical work are 'non-notifiable'?
The following types of work are non-notifiable:
* Replacing accessories such as socket-outlets, control switches and ceiling roses
* Replacing the cable for a single circuit only, where damaged, for example, by fire, rodent or impact (1.)
* Re-fixing or replacing the enclosures of existing installation components (2.)
* Providing mechanical protection to existing fixed installations (3.)
* Installing or upgrading main or supplementary equipotential bonding (4.)
* Work that is not in a kitchen or special location and does not involve a special installation (5.) and consists of:
o Adding lighting points (light fittings and switches) to an existing circuit (6.)
o Adding socket-outlets and fused spurs to an existing ring or radial circuit (6.)
and as you said it doesnt state a limit, so thanks for the clarification on that one.
I do see why you cant install a 230v fan in the bathroom, as it is mains voltage and installed in an incorrect place could become a danger... but it does seem silly that it applies to 12v fans.. even though those can be installed right over zone 1 due to the remote transformer... which could be in a loft space anyway where the mains voltage connections are made.. in which case your not technically brining mains voltage into the bathroom.
Not so.
This is Part P in its entirety:
You should probably read this: http://www.diynot.com/wiki/electrics:part-p
No it doesn't.
You may.
Whether you can or not is a separate issue.
No they aren't.
12V is not low voltage. See http://www.diynot.com/wiki/electrics:voltage-bands
As you can see, Part P applies to extra low voltage as well as low voltage.
