It's a mira with an integral pump. I plan to completely redo the shower room next month but wondered if it will keep till then
Balls! Ok. Out of interest what would happen to it if I introduced both hot and cold mains pressure (instead of just the cold at mains and hot from gravity as it currently gets)?
If you are lucky, a crack as the plastic shower body disintegrates, the roar of water rushing out, and then a click as the RCD cuts the electricity off, leaving you in total darkness with vast amounts of hot and cold water spraying all over the bathroom.what would happen to it if I introduced both hot and cold mains pressure
