Hey haggis, ta for the reply but the make and model were in the header. Have you seen my follow up - BG came to replace gas valve and baffles but also replaced the burner. I have a feeling i have been tucked up. Thoughts pleasewee bit more info dai bach
whats your boiler make/model
should the initial inspection have diagnosed the burner faulty as well as the gas valve and baffles?I still dont see how you have been "tucked up" as you put it. Explain how?
Gas valve yes turbulators no.
Surprised so much reference to them. Even if they have dropped they shouldn't cause a noise (resonance) problem, according to my original training (by the designer Dr Jackson) the IMI Powermax is fine to use with the turbulators dropped.
Following a few 'incident' it is now required to replace the turbulators if they had dropped!
