i have recently moved into a second floor flat and have a problem with my Powermax 155x boiler.
when the program clicks on (in timed mode) it seems to work fine but the pressure gauge rises to approximately 2bar before allowing any water to circulate around the radiators (after about 5-8minutes); it then continues to rise up to 3 bar(within10-15minutes of coming on) at which point i panic and turn the whole lot off, as it says to do so in the instructions.
this has only happened since i refilled the system, after the pressure dropped to zero and the lock-out light came on. When this happened i re-filled the system as instructed to do by an engineer (which i called out at great expense the first time it dropped to zero
i have both the user's instructions and the installation & servicing instructions and having read both i am still clueless.
please can anyone help?
i really don't want to have to call out an engineer if it is something straight forward (as i really cannot afford it )
Thanks in anticipation!
