- Joined
- 7 Aug 2006
- Messages
- 6
- Reaction score
- 0
- Country
I have just finished rewiring a property I am renovating. The rewiring is complete up to the point that all that remains is to disconnect the tails from the existing CU and connect them to the new one. In the past I have simple pulled the supply fuse and switched the tails over, however as we know there can be associated complications doing this, in particular the breaking of the seal…
To avoid this I am considering a different approach. The property currently has a pre-pay token meter installed and I am thinking that if I simply allow the credit to run out the supply to the existing CU is cut off. I could then switch over the tails with out the need to remove the supply fuse.
My question is: does anyone know if the supply is totally cut off when these meters run out of credit? Are both the Neutral and Live feeds isolated or is it only the live feed that is cut off?
Many Thanks
Many Thanks
